Stuck and need help M2P
NewJuice
San Francisco
Hi All,
I new to your forum and have an issue with my new Mavic 2 Pro. I've had it for two weeks and I'm having trouble with poor photo image quality and the GPS Metadata not showing on any of my pictures. I've been working with DJI support for a week and we are getting nowhere fast. I'm at the point of returning it.
I've watched you tube videos about camera settings, device setup, smart controller dos and don'ts, endless beginner guides. There are some great videos out there from really creative people but unfortunately not one has helped me. I'm hoping this is just a user issue that someone on here can solve. Returning my Mavic is the last stop.
Things I've done:
Updated smart controller firmware
Changed photo/video settings (currently at jpeg, auto white balance, ISO 200/ 4K 30fps,
Reset GPS, made sure 10 or more satellites are listed before take off
Running DJI GO4 v4.3.16 (latest version)
Thank You,
Sorry, here is an example of my issue. This is a picture I took with what appeared to be the correct settings. JPeg, GPS showed 10 satellites. changes white balance to sunny and started taking pictures
I'm not sure what you actually did but there is no way to "reset GPS".
GPS will have no impact on your image quality anyway.
The firmware version is also unlikely to have any effect on image quality.
What is the problem you have with that image?
btw .. An original image straight from your camera would be more helpful rather than a resized version that may or may not have had other modifications done.
When I try to submit the image to Dronebase it keeps getting rejected for low resolution and missing GPS Meta data. The image is directly from my SD card. Not sure how to fix this.
Low Resolution ...
That image is 1632 x 1088
Straight from the camera, it should be 5472×3648
Did you get the image from the SD card which is where you would find the original images?
Or are you looking at a reduced size thumbnail image?
The missing metadata is probably the same problem.
The original images will have the metadata but the thumbnails won't
You need to pop the SD card from the Mavic, put it in an adapter and put that in your computer to copy the full-sized original images to your computer
Hi,
I'm the image came directly from my SD card and is not a reduced image. Please note, this is from the SD card in my Smart Controller and not the drone itself. I wonder if it makes a difference. Here is an image directly from the SD card in the drone. DJI_0055.JPG
I see these images have the descriptions you were referring to. Hope image quality is at 5472×3648 and GPS Metadata is now present.
Please know I really appreciate your help. 10x more support than DJI can provide.
yes, please take a look when you get a chance.
The images that you posted above are full resolution M2P images including all the usual metadata, including location (GPS):
File Name : DJI_0055.JPG
Directory :~/Downloads
File Size : 7.3 MB
File Modification Date/Time : 2019:08:17 15:12:45-06:00
File Access Date/Time : 2019:08:17 15:13:36-06:00
File Inode Change Date/Time : 2019:08:17 15:12:45-06:00
File Permissions : rw-r--r--
File Type : JPEG
File Type Extension : jpg
MIME Type : image/jpeg
Exif Byte Order : Little-endian (Intel, II)
Image Description : default
Make : Hasselblad
Camera Model Name : L1D-20c
Orientation : Horizontal (normal)
Samples Per Pixel : 3
X Resolution : 72
Y Resolution : 72
Resolution Unit : inches
Software : 10.00.10.04
Modify Date : 2019:08:16 11:15:48
Y Cb Cr Positioning : Centered
Exposure Time : 1/2000
F Number : 5.6
Exposure Program : Aperture-priority AE
ISO : 100
Exif Version : 0230
Date/Time Original : 2019:08:16 11:15:48
Create Date : 2019:08:16 11:15:48
Components Configuration : Y, Cb, Cr, -
Exposure Compensation : 0
Max Aperture Value : 2.8
Metering Mode : Center-weighted average
Light Source : Daylight
Flash : No Flash
Focal Length : 10.3 mm
Warning : Bad MakerNotes directory
Flashpix Version : 0100
Color Space : sRGB
Exif Image Width : 5472
Exif Image Height : 3648
Interoperability Index : R98 - DCF basic file (sRGB)
Interoperability Version : 0100
File Source : Digital Camera
Scene Type : Directly photographed
Exposure Mode : Auto
White Balance : Manual
Digital Zoom Ratio : 1
Focal Length In 35mm Format : 28 mm
Scene Capture Type : Standard
Gain Control : None
Contrast : Normal
Saturation : Normal
Sharpness : Normal
Device Setting Description : (Binary data 4 bytes, use -b option to extract)
Serial Number : 0K8TG3M0120099
Lens Info : 28mm f/2.8-11
GPS Version ID : 2.3.0.0
GPS Latitude Ref : North
GPS Longitude Ref : West
GPS Altitude Ref : Above Sea Level
XP Comment : 0.9.142
XP Keywords : single
Compression : JPEG
Thumbnail Offset : 21142
Thumbnail Length : 17764
About : DJI Meta Data
Format : image/jpg
Gps Latitude : +38.0034393
Gps Longitude : -122.3160933
Absolute Altitude : +33.60
Relative Altitude : +12.30
Gimbal Roll Degree : +0.00
Gimbal Yaw Degree : -49.30
Gimbal Pitch Degree : -37.70
Flight Roll Degree : -7.30
Flight Yaw Degree : -42.70
Flight Pitch Degree : +1.10
Cam Reverse : 0
Gimbal Reverse : 0
Self Data : Self data
Version : 7.0
Has Settings : False
Has Crop : False
Already Applied : False
MPF Version : 0100
Number Of Images : 2
MP Image Flags : Dependent child image
MP Image Format : JPEG
MP Image Type : Large Thumbnail (VGA equivalent)
MP Image Length : 542694
MP Image Start : 7090695
Dependent Image 1 Entry Number : 0
Dependent Image 2 Entry Number : 0
Image UID List : (Binary data 66 bytes, use -b option to extract)
Total Frames : 1
Image Width : 5472
Image Height : 3648
Encoding Process : Baseline DCT, Huffman coding
Bits Per Sample : 8
Color Components : 3
Y Cb Cr Sub Sampling : YCbCr4:2:0 (2 2)
Aperture : 5.6
GPS Altitude : 33.6 m Above Sea Level
GPS Latitude : 38 deg 0' 12.38" N
GPS Longitude : 122 deg 18' 57.94" W
GPS Position : 38 deg 0' 12.38" N, 122 deg 18' 57.94" W
Image Size : 5472x3648
Preview Image : (Binary data 542694 bytes, use -b option to extract)
Megapixels : 20.0
Scale Factor To 35 mm Equivalent: 2.7
Shutter Speed : 1/2000
Thumbnail Image : (Binary data 17764 bytes, use -b option to extract)
Circle Of Confusion : 0.011 mm
Field Of View : 65.5 deg
Focal Length : 10.3 mm (35 mm equivalent: 28.0 mm)
Hyperfocal Distance : 1.71 m
Light Value : 15.9
Perfect, this confirms what I was suspecting. The images from SD card in the drone are the ones I should be using. Images on the SD card in the smart controller are just thumbnails for review.
Thank You so much. No I need to practice taking pictures. Any suggestions on good camera settings to use?
That was a full-sized original image. It includes the metadata as shown here:
Use RAW not jpg. Images will have even more detail to manipulate in post software like photoshop
LateParrot
