Stuttering of Image since v01.03.1000 and downgrade
Hello!
Lately I have noticed a very annoying stuttering of the image when I'm using the pitch axis of the gimbal
or when I rotate the mavic around the yaw-axis. The only thing that I have changed was the firmware version
of the controller and the Mavic from v01.03.0800 to v.01.03.1000.
The stuttering is visible on the smartphone video transmission, the recorded video on the smartphone and
the mavic footage on the sd card.
I have already tried different solutions:
1) Change of resolution, frame rate, video shutter times and ntsc/pal etc.
2) Image transmission switch from regular/hd to smooth
3) Use of an ND8 filter to optimize video shutter times
4) Recalibration of gimbal
5) Reinstallation of the v01.03.1000 firmware on the Mavic
As last option I tried to downgrade the mavic to v01.03.0800 with the DJI Go App and the DJI assistant.
Unfortunately I can now only choose between 3 different versions of v01.03.1000. All older firmware
versions are not listed anymore? Has DJI disabled the option for a downgrade???
I really hope that someone has experienced the same problem and/or can help me to downgrade to v01.03.0800 again.
Thank you!
Best regards
Andreas
I have had the same issue but also with "snow" interferance, found the solution was to not wear my lg smart watch. I suggest you check what bluetooth devices you have on you. Video example available if you want to compare it to yours.
rapidair
