HoozierDroneDaddy
- Joined
- Mar 12, 2017
- Messages
- 806
- Reactions
- 523
- Age
- 71
Sorry for the delay guys.
Do you have a target date for getting Litchi and/or Autopilot to work with the BT-300s?
Litchi works, you just need the correct version.Do you have a target date for getting Litchi and/or Autopilot to work with the BT-300s?
Thank you for the reply on Litchi. Do they have anything in the works for Autopilot? I have used it for the past two years with no problems. I thought about trying Litchi, but I have also heard of glitches with it.Litchi works, you just need the correct version.
Here is link to litchi:Thank you for the reply on Litchi. Do they have anything in the works for Autopilot? I have used it for the past two years with no problems. I thought about trying Litchi, but I have also heard of glitches with it.
Thank You. I will be purchasing the BT-300 soon and will use your info to set it up. Thanks for sharing.Here is link to litchi:
Credit to Iannes
Here are the files you need to copy over to the BT-300 and install
https://www.dropbox.com/.../AADcoNPh4JUT2p8vNeLaLxHVa...
Order of install is
Google play services
Google play info
Google play store
Maps Navigation Transport
Litchi 4.0.2 (this is only version that works at the moment)
https://www.modapkdown.com/.../com.mod.litchi-for-dji.../
Excited about this!!! I hope they fix the flight logs. That's important to me. Will it work with all Go4 aircraft? Mavic Air?ok - this will be multi-part !
I got a Beta "Invitation" from someone from Epson a few days ago - who let me download the Epson DJI Flight App. I spent a day charging and setting everything up to be ready for the weekend (more on that later). Weather was a bi*ch on Saturday with high winds - so no flying. And today as my lovely family asked me what I wanted to do for Fathers day (apart from the full kids schedule) - I of course answered - GO FLYING!.
So off we went to Richmond Park, London. The park is HUGE and have a dedicated RC Flying area. No paved landing strips and I think for electric flight only - it is a lovely setting with great views. I did manage to spoil any great camera footage by flying with EV -2.3 for the whole time as last time I flew was in Spain and I simply forgot to adjust.
Anyway - after 2 complete "reboots" to get the Moverio & Mavic to join hands - we had contact. Another Mavic Pro Pilot (Winston? I think) was there with his wife - and they graciously let me try their USB Cable. So thank you very much! But a CTRL-ALT-DEL was needed - and not new cable. But the fellow pilot got to wear my BT-300's - so I think Epson got a new customer...
So the new app in short. It is a simplified DJI Go app. It is designed to use with Epsons BT-3xx series. And it is designed to make it easy to fly "controller blind" - so the ONLY buttons you use while flying are the "C1/C2" buttons under your controller - plus the sticks of course. You do not TOUCH the BT-300 controller for "normal" use. Once you go into settings - you revert back to the track pad.
Default C1/C2 press Flight Menu - you use C1 to "scroll" and C2 as "select/enter" - so to get to Map mode - you click a few times on C1 - and select with C2 button.
So what else is new:
1. AirMap - the Epson Flight App uses AirMap - so you can download maps to use while flying "offline"
2. BirdsEye Flight - you turn your head - your turn your drone! Tilt your head up and down and gimbal tilts! I did not quite get used to it during the flight but I'm certain it will grow on me when I learn to turn EV back to normal brightness.
3. You can record video from the internal BT-300 camera while you fly.
4. HUD optimised views - so the whole app is designed for use with the BT-300. So in default screen mode - you have a tiny "map circle" in the lower left corner - and a drone video "circle" in the lower right corner - and a few and a bit of text and graphs - and that is it.
So see attached images!
Default Flight Mode Screen ("Optimised HUD View) - all the "black" area is what you use to See - Through and keep an eye on your bird. So in real life you see through the glasses where screen is black.
BirdsEye Flight: - plus BT-300 Camera recording called "Moverio Mode" (big red thing on the right is the camera indicator...)
As you can see I had a lot of GPS errors - and I did have my wife and 2 kids there - so there was not time for diving into "issues" as we had a birthday party to go to right afterwards.
But I'll see if I can push in a flight or two later tomorrow with more updates. I'll have to play around to figure out camera settings when flying etc. So 1 battery used so far.
Issues: Despite logging in with DJI login - the flight is not registered / sync'ed. Maybe that is not in the cards but I don't care anyway but some people might. Few "beta" niggles but I'll send them to Epson direct.
Any questions : Just ask!
But I am impressed! This makes it simpler to fly - and the screen is not annoying in front of you as it is with the normal DJI app. Great work Epson and all so far.
I would love a couple of "custom actions" so I could setup 2-4 icons myself that I could chose with C1/C2. So kind of "Macro's" for re-call of often used settings/combo settings.
As John Wayne said "now hold on there little britches"So any news when this app will launch? Seems like everyone keep talking but no sign it will go to live.
I own Mavic Air... Willing to test.So the new app in short. It is a simplified DJI Go app. It is designed to use with Epsons BT-3xx series. And it is designed to make it easy to fly "controller blind" - so the ONLY buttons you use while flying are the "C1/C2" buttons under your controller - plus the sticks of course. You do not TOUCH the BT-300 controller for "normal" use. Once you go into settings - you revert back to the track pad.
Great for Pro users.....But!
Are there any Mavic Air testers using the beta app?
