There are issues with the DJI Fly flight logs after they are uploaded to the DJI server.
Previously, we all know that if you record a flight with DJI GO 4 on one mobile device, upload, then log into DJI GO 4 on a mobile device and sync, all data is available on the second device.
However, when the data from DJI Fly hits the DJI server, it gets corrupted.
I record my flights using iPad Mini 5 with iPadOS 13.2.3
Once I sync and try to view on my iPhone Xr iOS 13.2.3, the data is not the same.
Same goes for Drone Logbook.
Case in point:
Flight device iPad mini 5 with iPadOS 13.2.3 logs display the following:
Distance 337ft Altitude 380ft Duration 21 min
Distance 413ft Altitude 390ft Duration 25 min
On the iPhone Xr with iOS 13.2.3 sync logs display the following:
Distance 39ft Altitude 19ft Duration 1 min
Distance 16ft Altitude 13ft Duration 1 min
Even worse on the logbook I upload to.
The flight was 1 second and could not identify the drone or the battery used.
The drone and battery used was working 24NOV19.
Attached file DJIFlightRecord_2019-11-25_[06-53-38] is right out of the iPad
Attached file 2019.11.25-6889-DJI is what comes out of the server
The 2019.11.25-6889-DJI is what was downloaded from Drone Logbook and is identical to what is downloaded from Air Data
Case in point:
