Hi Folks,
I damaged my right props back on May 24th and I'm trying to see the difference in motor speeds before and after I changed the props.
I lightly sanded the damaged props to smooth out where the slight damage was (and sanded the opposite prop for balance). However, I realized I have no way of determining proper balance between both sides so after a short hover test (May 24), I decided to swap out my props for a new set. (May 25)
I am really curious to see the difference in motor speeds.
This is where my issue lies. I'm using a mac and I've downloaded all the logs files, but between the TXT log files and the a CSV converter, there's some sort of breakdown of the file conversion and I get an error every time I use CSVView.
I've spend a couple hours trying to get this working (for future use as well) but I think I'm out of luck.
Is there any chance someone might want to take these files and convert them/spit out graphs for me so I can see the change of motor speeds between flights.
Logs are here:
2 Flight Logs
Thanks for your time.
KJ
Logs are here:
2 Flight Logs
KJ
