Turned Mavic Pro on without removing gimbal clamp
Dont think so, had forget myself a few times. Just dont make a habit of it. Also try to attach a ribbon od sort the holder. That helps to not to forget. Happy flying.
Forgot to remove gimbal clamp before powering it on, it went through it’s normal startup. Could I have damaged the drone in anyway permanently?
You are fine, most of us have done that at least once.
Does the gimbal still function as expected when you power on your Mavic? If so, you're good to go.
I remember to remove clamp before flight, but I forgot a couple of times when I turn on to connect to my laptop or update firmware at home.
bertmag
