Didn’t help, also tried phone off and then back on, no change there either. Thanks for suggestion. ?I’m using an iPhone 6 without issue, maybe delete app and reinstall.
No, they only sent one cable that would fit iPhone.Could be the cable, do you have another OTG cable?
Do you have another iOS device to test the cable, maybe an iPad?No, they only sent one cable that would fit iPhone.
I used same cable on iPad and had same message, ie: does not support. Does this tell me cable is bad?I do have an iPad. I’ll see if I can test cable on that. ?
It appears that the controller and the mini are connected because I get the slow flashing green light. Apparently that means I’m in PS mode with gps. I also tried other things like turning off my VPN and also turned off cellular data for Dji app. None of that seemed to help. I guess I ll have to search for another lightning cable on Monday. ?I used same cable on iPad and had same message, ie: does not support. Does this tell me cable is bad?
Do you know anyone with a compatible Android mobile? You could try another cable to make sure it’s not the connection to your controller. Controller will connect to aircraft over WiFi, this has nothing to do with your mobile device. Sounds like a warranty issue either way.It appears that the controller and the mini are connected because I get the slow flashing green light. Apparently that means I’m in PS mode with gps. I also tried other things like turning off my VPN and also turned off cellular data for Dji app. None of that seemed to help. I guess I ll have to search for another lightning cable on Monday. ?
Thanks for the response. I don’t know any android users, so I’m thinking my options are to buy/beg/steal another cable for troubleshooting purposes.Do you know anyone with a compatible Android mobile? You could try another cable to make sure it’s not the connection to your controller. Controller will connect to aircraft over WiFi, this has nothing to do with your mobile device. Sounds like a warranty issue either way.
It needs to be OTG, they’ll be lots of advice on the forum regarding what you need. Or just return the MM for a replacement.Thanks for the response. I don’t know any android users, so I’m thinking my options are to buy/beg/steal another cable for troubleshooting purposes.
Thanks for information. ?
? I’ll check to see if they will let me return it based on the discrepancy.It needs to be OTG, they’ll be lots of advice on the forum regarding what you need. Or just return the MM for a replacement.
RESULTS. I returned my MM TO Florida Drone Supply And they sent me a new MM. It connected without hesitation. Very Happy. Thanks Florida Drone Supply for the no hassle replacement.Just opened my new Mini from Florida Drones, read Manual, charged batteries, and opened Dji app. When I clicked on connect, I got this message
I have a iPhone 6S.
Anyone else have this happen?
