READ THE WHOLE THREAD BEFORE DOING ANYTHING!
I have gotten msgs saying the mavic pro also uses 5.8ghz NO IT DOES NOT!!! meaning when you are using the remote controller! but you can uses a dual band antenna meaning it does 2.4ghz AND 5.8ghz. don't buy just a 5.8ghz antenna cause its not tune to for the 2.4ghz!
if you are looking for bird ant mod then read this post:
Aircraft Antenna Mod
Hi
I thought I would start a thread just for CONTROLLER AMP ANTENNA MODS ONLY! this will help people find this information
Also the mavic has TWO antennas so you will need TWO of everything! meaning amps, connectors, cables, etc!!!!! you will only need one battery!! if the battery has high mah rating
the stock remote output is FCC 26 dBm = 0.398 watts (US)
CE:<=20 dBm = 0.1 watts
SRRC: <=20 dBm = 0.1 watts
MIC: <=18 dBm = 0.063 watts
keep in mind there is some dbi loss when you run it thru connecters, cables
When you post here please post links and what connectors are need
Thanks
Hi
Thanks
