While the DJI Assistant doesn't specifically call out the battery update, if you run it with different batteries, it will recognize/update (as a refresh).When I got my MA2 I updated the batteries when the app said to. But when using dji assistant 2 I plug in my controller and drone and both update but how do I check the batferies?
so refresh drone 3 times then for 3 batteries?While the DJI Assistant doesn't specifically call out the battery update, if you run it with different batteries, it will recognize/update (as a refresh).
Exactly: at least the last 2 cycle times are shorter (no drone update).so refresh drone 3 times then for 3 batteries?
