USB 2.0 or 3.0?
USB 3 are normally Blue in the Port. You will know if xfer is fast but would assume 2.0
Well, its kinda confusing since the communication cable provided in the box (the one you use to connect to a computer) has a blue USB-a end. However, the port on the RC is black.
Should clear it up. I know the TX is 2.0 if that helps
Edit: What the hell. Heres the symbols for each Standard including 3.1/Thunderbolt
Reactions: Phantomrain.org
Thanks. That was helpful.
maviclake
