Using my Mavic Mini 1 beyond photo/video/fly around
nld09
Atlanta,Ga
I used my Mavic Mini 1 to help me took down 100ft+ straight dead pine tree ?. Ok... I would not recommend doing it if you don't know what you are doing.
I used the MM1 to pull up a fishing line around a branch near top. Once that was done, I pulled a light duty rope with a fishing line. Afterward, I pulled a 3/4 inches heavy duty ropes (300ft total) up with the light duty rope. I then used a heavy duty rachet tie down to another tree (like 200ft away). I used two rachet tie down to tight it up until the pine tree lean towards that direction and I couldn't tight it up anymore. I pulled out my 16 inches gas power chained saw to take it down safety. Definitely you need all your PPE.
Save me $600 bucks... Enough to buy MM2 ?.
It's not a toy, it's a tool. :)
Innovating use of the MM1.
Very cool, how did you pull up the fishing line without interfering with the drone and how did you release the line?
I used a twist tie to the body of the mini to extend out the fishing line so it wouldn't interfere with props. I flied up near top of the tree, did almost 360 degree circle above a branch (to hold the fishing line), and then brought the mini back down with the fishing line.
Thanks 72evenant. It was a very simple but crucial step to safety took down the tree. With the MM1 small size and stability, it got the job done.
Reactions: 72evenant
elitewikipublishers
