Hmm ... unclear. I’d guess, from what you said, that you start both, ignore the warning from Litchi, and happily switch between them “on the fly”. Yes?Absolutely! Lichti gives one a warning message that DJIGO4 must be closed on the device and not just running in the background for Lichti to operate properly. I switch between the two programs on the same device without issue.
Good advice will try thanksFor me, I take off in the Go app, make sure everything is set, close that app, then launch Litchi and fly the waypoint mission. Works great.
I took a look at Litchi but could not quite figure out what waypoints are or how they help. Is there a ready reference to help the uninitiated?
I’ve seen that message from Litchi. Figured it meant there’d be unstable crosstalk somewhere down the software stack if both Litchi & DJI GO4 were in memory.
On my iPad Mini4, I can “close” GO4 with the home key, but it remains in memory (or is cached to appear so), probably running a residual stub. Swiping up on the home screen lets me truly kill the app, removing it entirely from memory.
So when you say, “closed on the device and not just running in the background” I’m not really sure what you mean, or at least what you do.
