I normally see a difference between the barometer height and the VPS height across a flight, but currently I am seeing this value be as great as 11m under the following conditions: at sea level, max flight height 30m, duration of flight 24min., air temp ~ 18deg Celsius, stable low wind conditions .....
Across a flight of this type I am seeing an increase in the difference between the two reported heights that can be up to 11m.
Previously I have seen maybe 1-2m difference between the two readings but to see the VPS reading of 5m and the h = -6m is kind of perturbing.
Some questions:
1.) Is this degree of height reading variance normal or is it indicative of a calibration or other error with the barometer (the VPS is accurate)
2.) The flights are directly by the ocean with quite a bit of sea mist... any possibility that this might lead to drift or change in the barometer reading.... the difference between the two readings increases over a flight but is reset if the AC is landed....
Cheers
Some questions:
Cheers
