Via the command line, can TXTlogToCSVtool process DAT files ?
  • Thread starter Deleted member 103366
  • Start date
D
Guest
I am looking through my flight logs for missing or lost .txt flight logs, checking the DAT's for motor starts is one way of doing it but doing it manually via CsvView is tedious.
Since TXTlogToCSVtool can be run 'en masse' on the .txt flight logs I was wondering if the same thing can be for the DAT's but so far I have had no luck.
Via the command line I have got it to process, one by one, one or two DAT's but the output files contained only the column titles.
Uummmm roflamo, there are none so blind as those that can not see........... WHOOPS
"couldn't see the wood for the trees"
Reactions: sar104
invertedloser
