Vibration hook
Saddisman
Hey ladies and gents. I'm trying to find the hook that holds the gimbal in place when flying. Had a crash today with my MPP and when i tried flying it after rhe camera was really shaky. upon inspection I realised that the hook was broken. I don't know if this will fix it but I'm willing to try. Also also if I purchase those "replacement" mavic parts would it work on the platinum aswell (since they're basically the same)
Thank you in advance.
Yes the part you refer to called the Anti Drop Hook (as I recall) can be purchased and its the same part as on the Pro as on the Platinum.
Can you link me yo it because I've been searching and only coming up with the entire anti vibration plate. On the plus side a dremel/sandpaper, a piece of plastic and some crazy glue seemed to help for now.
Let me tag @Thunderdrones as he can assist with the exact part that you need to replace and tell you if you must buy the entire assembly or if there is a sub assembly that is what you need.
MacPilot55
