Voltage loss in controller while hooked to 5.5 Crystal Sky
Pepperbr
While using my Mavic 2 controller I have noticed a voltage drop while using my Crystal Sky 5.5 inch. The controller was 100% charged in the beginning and dropped to 21% with in 15 min. Outside temp around 52 deg.
When I brought it back home not connected to crystal Sky and controller turned on it was charged at 73%. Looking for recomendations
Thanks
Hi Pepperbr,
Sounds like your battery in the CS was not seated and you were powering the CS from the controller. I didn't think that was possible but I just removed the battery from my CS and using a USB A to USB C OTG cable the CS will power up. Check the CS battery and be sure it is fully charged then install it in the CS but do not connect the OTG cable and see if the CS powers up. If everything powers up I would suspect the battery was not fully seated.
~Bill
Reactions: CJH92474
natty_gd
