I have noticed there seems to be couple of issues with waypoints. I wonder if anyone else has identified them.
Firstly when you add waypoints and then put in a POI tap on the poi and select the which cameras you wish to point to it the numbered check boxes appear but the first one, instead of saying "All" has a chinese character for what I presume means the same thing.
Secondly and more important, when you save your waypoints to a task it automatically gives it the filename and date/time etc and you can only edit the filename manually by opening the task list. BUT what is the "save as" supposed to do? This only appears after you have saved the task you are working on so the normal protocol for "Save as" is so that you can save an alternative and name it. It currently doesn't seem to do anything other than save. Unless of course I am missing something?
