Weak signal durning time demanding task
MGVision
If i am creating for example sperical panorama or other time demanding task and durning that time i will experience signal interference, can it cause some kind of distorion, glitches or not perfectly matches photos in final content? Should i always do those kind of tasks only when i have good signal?
A strong signal is always best, but intermittent temporary dropouts probably won't screw up a task like you describe. Lengthy total signal losses are probably another story.
Reactions: MGVision
No because the footage is stored on the SD card of the drone. If you copy from there the signal strength (as long as you don't disconnect) is irrelevant.
Reactions: MGVision
What then can cause distortions like this? Why photos are not perfectly stitched together? Dji 0995
Sometimes wind can cause the drone to slightly drift between shots, which causes the stitching to not match up.
Reactions: MGVision and lannes
Andresc.castrog
