What am I doing wrong here?
3:16
Delaware, USA
Look at the lines on the road, looks like dots it’s on all my pics
Are you just opening the low res thumbnails?
Where are you getting the pics from, what format are they, and what are you opening them with?
Reactions: Thomas B
This is expected, depending on how the software developers made the software that you're using to view/preview your photos in.
If you look at those same photos in another software at the same exact size, you may or may not see the same effect.
It is one way that a computer can calculate where to put pixels, and what to do with areas that share different qualities of pixels, when an image is scaled. Ask more questions and I'll tell you more, but if you research "scaling interpolation" you'll probably find enough.
Reactions: Cymruflyer
Those pix are tiny thumbnails, only 960px × 640px.
Look at the real images which will be much larger and better.
Reactions: Thomas B
Ok that makes sense, because when I pull them into light room they show fine. Learn something new every day Thanks
Reactions: Rockycat
d702c
