D
Deleted member 109934
Guest
Do you guys do battery maintenance as per airdata, or just fly your bird to 20-30% and keep recharging? Does regular maintenance like below extend battery life if yes any clue by how much?
Battery Deep Cycle Discharge
When you deep cycle the battery, it also re-initializes the battery's internal software. Always allow a LiPo battery to cool completely before any recharge to help protect your battery and extend its life.
Slower Deep Cycle Method:
- Fly until battery level reaches 25%-30%
- Allow battery to cool completely to room temperature
- Put battery back in and turn on aircraft (optionally starting motors with no propellers) and allow battery to discharge until it gets down to 8%, or until the battery can no longer be turned on. Launch the DJI GO app to check battery levels.
Important: NEVER fully discharge the battery to 0% - it can cause permanent damage
Tip: With engines stopped, the battery seems to drain about 1% every 5 minutes or so - Allow the battery to cool completely again to room temperature
- Recharge battery normally
- Fly the aircraft outdoors until there is less than 8% of power left, or until the battery can no longer be turned on.
