Anybody got any ideas?
Flashes, Temp Shifts... Why?
It's all shot Manual, ISO 100, locked shutter speed.
You need to use manual white balance. What you are seeing is auto white balance trying to compensate for the changing color of the sunset
I definitely do take everything in raw. That's upsetting though, I wish it would just lock in a temp when I start shooting. Everything else is locked...flashes appear to be flicker. Not sure why as you are in manual mode with aperture and shutter speed fixed.
I have seen this from many hyperlapses from the MP2. Especially in low light or scenes transitioning to low light.
Color shift is from white balance changing I would assume from the light changing. I don’t believe you can set a fixed Kelvin value for WB with the drone at least I have never looked for it. You can pick the standard settings.
You might consider taking the hyperlapse in raw and jpg that way you can work it up manually. However much much more work involved.
Paul C
Where is the setting for white balance on DJI FLY?You need to use manual white balance. What you are seeing is auto white balance trying to compensate for the changing color of the sunset
Here’s my experience...
I looked right past this too many times to count!
My man I have to introduce you to DaVinci Resolve where you can make videos from DNG sequences and get RAW controls for the videos during the video editing process. It’s life changing for time lapse photographers and would solve our friend’s white balance issue due to the ability to set white balance in post with the power of RAW. It’s free.Here’s my experience...
The flashes are due to incomplete exposures for individual frames. Not sure why it happens. I have done many time lapse videos, and every once and a while a bad jpg will show up out of a several hundred shots. I’m using an MPP and I post process using FCPX. Before combining jpg’s into a clip, I quickly do a visual scan for bad shots and erase them. For other drones, I dunno. Maybe for you automated pilots take a look at your SD card?
I'm working the footage through LightRoom now, didn't know about the manual K settings, super excited for new stuff.My man I have to introduce you to DaVinci Resolve where you can make videos from DNG sequences and get RAW controls for the videos during the video editing process. It’s life changing for time lapse photographers and would solve our friend’s white balance issue due to the ability to set white balance in post with the power of RAW. It’s free.
This was the final straw for me to switch to Resolve from FCPX which doesn’t support DNG sequences and I’ve never looked back. It’s a little painful at first to teach an old dog new tricks but once you do you will wonder what the heck you’ve been doing all this time.
Did I mention it’s free? Trust me on this.
Lightroom isn’t a proper program to edit videos and I believe you can at max export 1080p time-lapses and all edits are global. Shoot in RAW and use DaVinci Resolve to edit your video.I'm working the footage through LightRoom now, didn't know about the manual K settings, super excited for new stuff.
I'll post the new stuff when it's done.
In LightRoom Classic I use the .DNG files and edit the first image of the Hyperlapse set, then copy those settings to the whole set, adjust as necessary...Lightroom isn’t a proper program to edit videos and I believe you can at max export 1080p time-lapses and all edits are global. Shoot in RAW and use DaVinci Resolve to edit your video.
All you do is put all the DNGs from the time lapse in a folder and then use the import dialogue in Resolve to go to that folder and Resolve will automatically recognize that the photos in that folder is actually a video and create at 12 bit video for you automatically.
You can do the same thing with jpegs but if you do you only get 8 bits to work with and if you do it in RAW you’ll get an extra menu of options in the color tab called “RAW.”
The RAW menu will allow to edit in 12 bit color and give you plus or minus 3 stops of exposure latitude. You can make true HDR video with that kind of power. If you’ve ever heard of CinemaDNG that is exactly what this is. I’m telling you guys it’s amazing.
Please listen to what I am saying to you because it will save you so much time and allow you to make SO much better time-lapses. You are doing this all wrong.In LightRoom Classic I use the .DNG files and edit the first image of the Hyperlapse set, then copy those settings to the whole set, adjust as necessary...
Then I export to a folder, import in to Premier Pro as an image sequence, do any final touches with key-framing if necessary, add audio, sync it all up, then export.
It might be more work, and not free, but it's what I'm used to.
LightRoom is more user friendly also, again, IMHO. Maybe not LR Classic, but definitely LrCC. (Note: as far as I know, Timelapses can only be edited in the classic version, not the CC version)
No problem happy to help. Warp stabilizer should be the same in AE as PP so whatever floats your boat.@brett8883
I have been baffled as to why my Hyperlapses look like "sheet" compared to 99% of everyone else's. This explains EVERYTHING.
Thanks man.
I've already done all the work in LR for today's stuff so will be exporting that tonight hopefully.
I'll run the same stuff the exact way you told me to through Adobe and post the results tomorrow.
Thanks again!
Edit: warp stabilizer in AE or PP?
If you are having those white balance color shifts though this will fix it because white balance is just metadata in the raw data, it can be changed by using the power of RAW in post just like as if you set wb manually in camera so this is a sure fire way to fix that issue. The flickering too. LR struggles to reliably sync and export hundreds or thousands of photos at once because it wasn’t really designed to be used that intensely. Your flicker I virtually guarantee is LR choking on doing all that all at once.I'll run the same stuff the exact way you told me to through Adobe and post the results tomorrow
What’s a DNG sequence? Where is it at? What resolutions is it? How is stabilizing accomplished?My man I have to introduce you to DaVinci Resolve where you can make videos from DNG sequences and get RAW controls for the videos during the video editing process. It’s life changing for time lapse photographers and would solve our friend’s white balance issue due to the ability to set white balance in post with the power of RAW. It’s free.
DNG files are the same thing as RAW.What’s a DNG sequence? Where is it at? What resolutions is it? How is stabilizing accomplished?
A dng sequence is a video made up of DNG (RAW photos) instead of jpegs like you’ve been doing.What’s a DNG sequence? Where is it at? What resolutions is it? How is stabilizing accomplished?
