When I put the filter on the lens it vibrates a lot
Abu Elias
oman
I have a problem with the lens without the filter, it works fine without any problem, but when I put the filter on the lens, it vibrates a lot, what is the solution
Reactions: MAVE (Little bird)
They're a bit like DUREX® you have to fit them properly, not sure what's vibrating (is that a girl thing?)
snap on
Check!
It is too heavy for the gimbal to handle fast enough. The gimbal control logic is quite delicate requiring a mass within narrow bounds of what is supplied as factory equipment.
Reactions: Abu Elias
I had that problem (with Freewell filter) turns out I didn't have it mounted properly. They are tricky little devils.
Gadget61
