Where is the GPS/Antenna on M2P?
Covering the sensor?
The lesser of two evils ... Cover the upward sensor or the GPS antenna ...
Better is the location directly on the battery - Velcro is your friend :cool:
Don’t think the mounts in my pics above cover sensors at all... and top is rubber.
Yeah, i thought the OP wanted to mount the Lume Strobe and not the Lumecubes as you have.
Reactions: Thomas B
Yes this is correct. The single lumecube strobe for 107 twilight flying / night regulations. Sorry if I wasn't specific enough, I was typing on my mobile. I figure it will have to go on top somewhere.
If you look at an enterprise dual the stuff just mounts right on top of the drone.
Even the speaker which has magnets in it.
If you mounted on the battery you’ll have to put Velcro and all your batteries.
That’s where I mounted my strobe no issues with GPS
So if DJ Is was OK with lt that it’s probably fine.
I own a set of cube lights. but my setup is not like that.
where did you get that strap to connect the lights on the body?
my cube lights connect on the legs. I like your setup better than mines.
Looking at the website it appears the mounts have changed to the arms, likely to allow easier battery changes on the drone. Maybe contact them directly or try eBay, etc.
To answer your question, the Mavic 2 Pro's GPS Module Board is directly under the shell, between the two front-arm pivots, in front of the battery compartment.
Reactions: OurAngryBadger
thats the way mine mount on the arms.
multimrslon
