Why are the lines flickering?
I saw flickering twice ... is that right?
Is your SD card up to the job ?
is it happening on every fluight?
I didnt see any flickering much other than the white lines that look like running water on the fottbal feild.
But i dont see anything on other areas.
Maybe something to do with sharpness?
it is the sharpness thing, I noticed that when I was filming a football field. I turned down the sharpness a bit and the flickering was a lot less noticeable.
You say you are using a SanDisk SD card - but is it 'UHS Speed Class 3' rated? In other words, does it have a logo that looks like a letter 'U' with a 3 in it?
U3 cards are capable of sustaining the write speeds needed for HD video- while UHS Speed Class 1 (U1) cards are not.
Dont know about the M2Z but this has been seen in M2P :
1080p 60 fps :
1080p 30 fps :
When shooting 60 fps, the camera, for some reasons, under-samples the image , does interpolation followed by sharpening. If the image contains fine lines like that in the video above, annoying flickering of the lines will show up.
I am using speed class 3 card.
Reactions: FoxhallGH
That depends.
Im using a sandisk ultra uhs-1 with a U1 in the letter U with a karma drone.
It handles 4k 30fps no probs.
My mavic air uses sandisk extreme U3 with 3 in the U and it has thesame flickering lines.
Seems to be normal because when i added post sharpening in davinci woth karma i get thesame flickering in davinci and rendering final film.
maliyindian
