I guess title says it all. The two things that come to mind are 1) you want them to blink, and 2) the angle of the light is too much down, and not enough to the sides.
@jeplane i guess your answer say it all i agree with everything you said and i hope the OP now knows why we do itWe have white bright LED on the Mavic 2?
Oh you mean on landing at dusk?
Otherwise, the reason why I use strobes are:
- The installed lights on the Mavic are not bright enough, and do not meet the 3 miles requirements to fly at dusk-dawn from the FAA.
- The strobes I installed are so bright, that I can more easily see the aircraft, even in daylight. This is crucial when flying at an altitude with trees in the background as an example. I can now see it Vs losing it in the busy background.
- The peace of mind that the aircraft has a better chance to be seen by manned aircraft, especially at dusk/dawn.
The truth is that if you would use theses strobes, you would know how useful they are, and you wouldn't have even started this thread....;-)
I don’t use my drone battery to run the landing light (except in low light landings), which you reference, all the time. I want the battery power to let me fly longer.I guess title says it all. The two things that come to mind are 1) you want them to blink, and 2) the angle of the light is too much down, and now enough to the sides.
These look good- how many do you run?I don’t use my drone battery to run the landing light (except in low light landings), which you reference, all the time. I want the battery power to let me fly longer.
The stock lights on the arms are not much use except for determining the M2P is functioning correctly at the time of take-off. They become invisible to me at a couple of hundred meters. This makes VLOS excessively hard and limited.
My Firehouse ARC2s allow visibility of 2-3+ miles, best at sunrise and sunset. They also allow visual determination of orientation. They may add to safety, but are not a substitute for LAANC flight clearance in busier airspace.
4 total: a red and a green on front arms and a white on each rear arm.
Cool- thank you.4 total: a red and a green on front arms and a white on each rear arm.
Correct. Adds about 30 seconds to my preflight.Guessing Nautical setup?
You need to park the boat trailer somewhere?Correct. Adds about 30 seconds to my preflight.
... noYou need to park the boat trailer somewhere?
That 30sec is mounting them or you leave them attached?
Where do you get strobes-- sounds great
Yup firehouse direct or Amazon whichever has the best deal. Next I recommend Aerial-Pixel for the mounts so you can put them wherever you want on the quad or like I did buy a set for my M2P and P4P.drone dji strobe lights spot lights
DJI drone strobe lights spotlight uas unmanned aircraft faa 107.29 mavic Inspire matrice phantom spark yuneec typhoon h parrotwww.firehousetechnology.com
Agree... see the pic in post #7 above. You have the option on the front of arm mount and leg mount. They fit fine over my PolarPro landing gear.
