Most of you know me for this thread Why I do believe there's a HUGE problem with the Mavic Mini - Flew AWAY the 2nd day
where I describe my experience of having the drone go missing before my eyes.
Quick recap:
My smartphone interface goes black and white during flight and says Aircraft not connected with RC but this is COMPLETELY WRONG because in DJI dictionary the RC is the one with the control sticks and antenna, while the attached device is called the mobile device. When this happens the AC continues to be coupled with the RC and responds promptly to user input.
Furthermore I get a bogus notice of Caution: Adjust antennas, if connection is not regained in 11 seconds failsafe RTH will be initiated, I've already tested no RTH will ever be initiated because the AC is still connected with RC. Again the information given is WRONG.
The mobile device remains in this suspended state until I pop out the RC cable and plug it back in again, after which the connection is restored and the mobile device works normally and correctly reporting the AC state.
This happened multiple times during the course of one day.
My mobile device is a Samsung S9+ G960F/DS. I'm quite OCD about every device I own, so everything is kept in perfectly good order, tidy, absolutely clean and functional. I am not the one with hair sticking out device ports.
This kind of occurance probably led the the loss of my first Mavic Mini. It happened while it was hovering 300m from homepoint. I think DJI should take full resposibility of what happened to my first Mini and compensate for it...and I am thankful to myself for having been so careful with my flights and able to isolate this problem.
Here's some short videos of the problem while it is happening:
Quick recap:
- complete sudden (apparent) loss of link (up/down) with no warning what so ever in full signal strength
- failed to RTH
- flight log data abruptly interrupted as per the first loss of link
- drone not found anywhere after thorough inspection of the neighbourhood for weeks
- I've tried wiggling the cable: no result
- I've tried wiggling both port plugs: no result
- In one occasion the mobile device restarted itself shortly after losing connection
