Wifi only connects for a few seconds then dissconnects
peterc4
manchester
Hi All had my smart controller since it came out and have had no wifi issues however i have just changed to vodafone now my smart controller will only connect for 15-20 seconds then cuts off if i click connect same again connect for 15-20 seconds then turns off, thinking this is something to do with my new vodafone router any ideas cheers
I take it you mean the connection of the Smart Controller with your wifi at home. When you changed to Vodafone, I suppose the SSID (name) and password of your wifi changed. I also suppose you selected this new wifi network in the settings of the Smart Controller. Or not?
Yes its all configured and connects with no issues problem is the connection stops after a minute or so. Thanks
Did you ever solve this issue as mine is doing the same, also smartcontroller and Vodafone broadband
Corbo2000
