Video is not playing.Thanks for your help. The path seems to run correctly now except the orientation of the drone should not be forward, but rotated outwards towards the Lake. Thats not happening.
This should have been fixed. Would you mind sharing the mission to me?I've experienced the same below ground issue between a couple of waypoints that @Mosvold described.
You can make the mission public in Litchi Hub and then share the URL.I would love to share the mission with you, but I'm not smart enough to attach a KML file. All my KML files are greyed out when I try to attach.
Have you unchecked it as private?
Sorry it took so long, I fixed the problem.
Editing file should not be needed. Could you share the missing so I could look?Hello, Bazuchan, I have been using Chrome VLM for a year, thanks for your excellent work! but recently the elevation is wrong much higher Than the actual. I reinstalled Chrome, I deselected terrain but still failed and I have read #23 to change the file to relative to ground but I don't know how to do it, can you please help? Thanks so much! Rex
Here is the link: Mission Hub - Litchi thanks very much!Editing file should not be needed. Could you share the missing so I could look?
