- Joined
- Jun 21, 2020
- Messages
- 3,977
- Reactions
- 3,962
One of the forum members was saying that different cables provide different efficiency in charging the MM batteries. I was curious, so for $8 I bought one. I had previously purchased one (then another) of those Yx battery adapters for the MM batteries. I'd already owned two QC 3.0 chargers so at around $12 each they were cheap. My experience was that my MM batteries charged in about 80 minutes, but I wanted to see if the meter told me anything. I'm just not sure how to read it.
Am I correct in interpreting the readings below as the battery taking 2858mah and being fully charged from low batter state in 81 minutes? When it's charging it's pretty cool how it tells me how many volts it's charging at. My only other question is, with the QC 3.0 while the voltage can be as high as 12v, the amps tend to drop as the voltage increases. While I have no complaints about the charge time, am I correct in seeing that higher voltage lower amps charges faster than a standard 5.12v at something near 3 amps?
