I am sure I am missing something very simple here. I can take the super resolution shot, but when I open the sd card it is split into each individual shot. Where is the stitched picture?
Are you doing it like this?:
https://www.facebook.com/DJI/videos/mavic-2-quick-tip-super-resolution-photos/314004389332255/
Yes, The pano folder is there with the 10 or so individual shots, but the stitched image is not in the media folder.
It should be in the same folder as normal ***** and videos unless you're in a hurry and press the shutter/change mode after it's taken the last picture but before it's done stitching, which would cancel it.
I was going off memory, It is indeed only 9 images. I have mine set to to both jpg/raw. Maybe I need to turn off raw?
The 10th image is is just a normal single shot version of the same thing at the wide angle setting. Probably so you can compare that with the super-res version...
That was kind of the impression I got from viewing it.
Still not sure why I have to build the Pan myself using other programs or apps.
The 10th frame so to speak is actually the first which the 2Z uses as a reference frame for the 9 subsequent ones...
Apologies - @Kilrah mentioned they thought the ‘low res’ shot was taken so you could compare to the super res one and you said you got that impression too.
Was just explaining what the low res shot was actually for.
With regards to the issue you’re having it does sound like somehow you are accidentally killing the routine before it’s finished. It can take a couple of minutes for it to get done.
Maybe try turning off the "save originals" option, take a shot and see if it's there? Then turn it back on?
I don't have a single super-res that didn't get its stitched version... even if I don't care about it since I'm always going to stitch the originals myself anyway, so much better - maybe we can swap?
