Zoom with Fn button on MA2 (not s). Is it still there?
twickers14
UK
Hi. A little help would be much appreciated. I watched a really good YT vid on this function and the clear instructions are, in video mode only, hold down the Fn button and at the same time scroll the gimbal wheel up and down (presume zooming in and out). Mine doesn’t work. Am I doing something wrong?
You're probably not in normal mode ,zoom doesn't work in dlog or 4k 60fs ,check what camera settings are then try it
Got it and many thanks! Was in Normal but you have to be in 4K Zoom (was in Wide) to be able to use the Fn and gimbal wheel zoom facility. I’m shooting in 25fps-perhaps I should up it a notch to 30fps? Also can’t seem to be able to move the gimbal left and right as the YT vid showed. Any thoughts? Too hot for Bristol Balloon Fiesta balloons to take off here this evening-what’s it like in Manchester?
Scottyg2s
