Compass Calibration Guide
msinger
DJI Drone Expert
Approved Vendor
Harrisburg, PA (US)
Site
mavichelp.com
Why Calibrate?
A good compass calibration is important to ensure a safe, controlled flight.
Warning Signs
The Mavic can only detect when the compass is providing extremely poor (implausible) data. This typically occurs if you place it near a strong magnetic field. It will flash red and yellow lights and the Mavic will indicate a compass error in the app.
IMPORTANT: The lack of a compass error does NOT mean your compass is working and calibrated properly.
Compass Interference
You can view the current compass interference in the "Main Controller Settings" --> "Advanced Settings" --> "Sensors" section of DJI GO. The colored bars should be in the green (Excellent) range when the Mavic is in a location that is away from magnetic influences. If the bars are in the red (Poor) range or close to it, move the Mavic to a different location and check again. If the compass interference is still in the red (Poor) range or close to it, the compass could need calibrated or it could be magnetized/damaged.
IMPORTANT: A good compass interference value does NOT mean your compass is working and calibrated properly.
When Should I Calibrate?
You do not need to calibrate before every flight and in some cases you definitely should not calibrate. That doesn't mean you shouldn't ever bother doing it. It only takes one time for it to go very wrong.
IMPORTANT: The ideal place to calibrate is an open field with nothing metallic in a 20 ft radius. Keep away from drainage pipes, irrigation systems, rocks, etc.
  • DO Calibrate
    • Compass interference values are out of whack or compass error is reported (check area first).
    • Circling in flight (also check for other possible causes).
    • New equipment added or removed.
    • If you just degaussed your compass (BTW, don't degauss unless instructed).
  • DO NOT Calibrate
    • If near concrete, buildings, and hidden or overhead power lines/pipes/etc.
    • If you're indoors, on a paved surface, on a stone surface, on the beach, on a boat, on a balcony, near a car, near speakers, etc.
    • If there are magnetic metallic objects nearby or you're not sure
  • Pre-Calibration Checklist
    • Everything used in flight should be powered during calibration (e.g. GPS tracker).
    • Remove all metal from your person that could potentially be held near the Mavic while you're calibrating (e.g. watch or rings).
    • Calibrate on grass or dirt and not on concrete/asphalt (unless you know the concrete/asphalt does not contain rebar).
  • How to Calibrate
    • Power up your Mavic and accessories as normal.
    • Wait until your Mavic is ready to fly.
    • Select CALIBRATE under AIRCRAFT STATUS | COMPASS. Click OK.
    • Confirm solid yellow rear lights.
    • Pick up the Mavic and turn it smoothly and steadily a full 360 degrees until the lights turn solid green.
    • Point the front of the Mavic straight down and repeat until the lights turn off and resume normal flashing.
      Note: Don't be concerned if your gimbal reacts poorly to being face down, keep turning as normal.
If for any reason you do not complete any of the above steps smoothly and evenly, restart the process.
Note: A lot of this information was copied over from ianwood's thread in the Phantom Pilots forum.
I'll stress something from using a Phantom 3 in the arctic. North is not magnetic north above the arctic circle. Calibrate your compass every time you use it. A coworker crashed his Phantom 2 prior to my arrival because of his compass calibration (it flew...and then nosedived). Mine was a bit better but wandered A LOT if I didn't do a preflight cal every time even with GPS lock. After the cal though...no issues. GPS connection is oddly flaky above the arctic circle for some reason even though it's supposed to be global. I would lose GPS nav quite a bit. I am assuming that the Mavic Pro will do better but best be safe.
GPS connection is oddly flaky above the arctic circle for some reason even though it's supposed to be global..
For GPS satellites the (orbital) inclination angle is 55º and for Galileo the planned inclination angle is 56º. This means in practice that no satellites signals are received in the zenith direction north of the corresponding latitudes (i.e. north of 55º and 56º N). If the GNSS receiver is located further north, the elevation angles of the satellites is reduced as the latitude increases.
Source : Coordinates : A resource on positioning, navigation and beyond » Blog Archive » Challenges for Positioning and Navigation in the Arctic
Ah duh you are correct. For some reason I forgot that little tidbit. I did get signals, but at 76º N the angle was terrible.
So I live on Oahu, Hawaii, and it sounds like I calibrate once in a large open field, and I don't have to do it again unless prompted or flying in the mountains? The radius of the island is approximately 20 miles.
Right -- you shouldn't have to calibrate on every flight if you're only flying within that 20 mile area.
Why Calibrate?
Compass calibration is important to safe, controlled flight. It compensates for changing background magnetic "noise", a.k.a. magnetic inclination and deviation. Inclination and deviation that isn't corrected through compass calibration will cause inconsistencies between GPS and compass that can result in "toilet bowl effect", a swirling motion that can cause the Mavic to fly out of control.
What is Magnetic Inclination and Deviation?
Magnetic deviation is a horizontal variation that comes from the Mavic itself and the equipment you have installed on it as well as the magnetic makeup of the area you are flying in (again not to be confused with declination). Sometimes the deviation will be insignificant, but other times it can be big enough to cause you to lose control. Inclination is a vertical magnetic variation that shifts depending on where you are.
Warning Signs
The Mavic can only detect when the compass is providing extremely poor (implausible) data. This typically occurs if you place it near a strong magnetic field or do not calibrate it properly. It will flash red and yellow lights and the Mavic will indicate a compass error in the app.
MOD Value
This is the total magnetic field calculated using the "sum of squares" from the X, Y and Z axes. You can see it in the DJI GO app. It should be between 1,300 and 1,600, ideally just above 1,400. Check it away from magnetic influences. If it reads very high or very low, check it again in a different location. If it is still off, it could need calibration or it could be magnetized or damaged.
IMPORTANT: A good mod value does NOT mean your compass is working and calibrated properly. For example, if you calibrate next to some rebar, your mod value may still be OK until you fly away from the rebar.
What Does Calibration Actually Do?
Calibration measures the magnetic fingerprint of the surrounding area. By turning the compass 360 degrees, the Mavic can see where the compass reading doesn't smoothly increase or decrease. It uses this information to build an adaption table so that when the Mavic turns during flight, the reading is smooth and linear.
You do not need to calibrate before every flight and in some cases you definitely should not calibrate. That doesn't mean you shouldn't ever bother doing it. It only takes one time for it to go very wrong. The most important aspect of compass calibration is making sure the magnetic "neighborhood" around your Mavic is consistent between calibration and during flight.
  • DO Calibrate
    • Mod value out of whack or compass error reported (check area first).
    • New equipment added or removed / new firmware installed.
    • Location change (greater than ~100 miles).
    • Significant change in terrain (e.g. to / from mountains).
  • DO NOT Calibrate
    • If near concrete, buildings, and hidden or overhead power lines / pipes / etc.
    • If there are metallic (ferrous) objects nearby or you're not sure
    • Everything used in flight should be powered during calibration, e.g. GoPro, tracker, etc.
    • Remove all metal from within 10 ft radius, e.g. watch, phone, ring, belt, coins, controller.
    • Calibrate on grass or dirt and not on concrete, asphalt.
    • Calibrate on a level surface if possible.
    • A cardboard box is a good idea to get it off the ground and level.
  • How to Calibrate
If for any reason, you do not complete any of the above steps smoothly and evenly, restart the process.
thanks for this...i've only had racers before this...thanks for the lessons even though i've done so much research i've seen something like this...awesome work getting it here though because compass calibration is important...im new to compass calibration so thanks...i take whatever i can get
Reactions: jointeffort
So... You mention some empirical measurements that don't necessarily imply a good calibration (and can't be trusted to imply a good calibration like mod value and compass error). Are there any that actually DO indicate a good calibration or do you just have to calibrate as best you can and hope?
After you complete the calibration process, the Mavic and DJI GO will alert you if the calibration failed.
Reactions: chazzm
Why Calibrate?
Warning Signs
MOD Value
  • DO Calibrate
  • DO NOT Calibrate
  • How to Calibrate
Thanks. Questions:
  1. Does the center of rotation matter? Recently I've see a lot of videos where the user rotates the drone in a circle around their bodies vs using the drone as the center axis of rotation. The DJI wikis and FAQs say to rotate the drone only. I have always done this by holding it off to my side and rotating my body in a wide circle keeping the drone in the center. (Otherwise, it was a two-handed operation and it wasn't very smooth.)
  2. I've used the DJI Assistant in the past to look at the Mod data for the compass. Is 1400-1600 still a good nominal range for the Mavic?
It does not matter if you rotate the Mavic in your hands or hold the Mavic still and turn your body. I personally turn my body since it eliminates the risk of accidentally dropping the Mavic.
The DJI GO app now displays colored bars to show the amount of compass interference. I updated that section above since the mod values no longer apply in the more recent versions of DJI GO.
Thanks! Where are the bars displayed, btw?
You can find them in the "Main Controller Settings" --> "Advanced Settings" --> "Sensors" section of DJI GO. You will only see them if your Mavic is connected to DJI GO.
Reactions: Rom3oDelta7
Why Calibrate?
Warning Signs
IMPORTANT: A good compass interference value does NOT mean your compass is working and calibrated properly. For example, if you calibrate next to some rebar, the compass interference might report good values may still be OK until you fly away from the rebar.
  • DO Calibrate
  • DO NOT Calibrate
  • How to Calibrate
The Mavic manual says "Only calibrate the compass when the DJI GO app or the status indicator prompt you to do so." Do you think this indicates that Mavic's software has been designed to eliminate the need for manually checking compass interference values?
No. It only indicates that the DJI manuals are not always the best source of information.
Thanks msinger, this was very good an thorough information. I guess the people who always respond with "read the $@&#% manual!" whenever someone asks a question, might not be giving the best advice :)
The manual isn't all bad though. It's chock-full of a lot of great advice.
I wouldn't hold your breath on Galileo - they will not make their planned 30 orbital by 2020, they are already years late and billions over budget.
Oh , and so far, not enough satellites have been ordered to even reach the proposed 30.:rolleyes: That doesn't include the three that are already faulty (and probably will need replacing)
We will all be flying Mavic 20's by the time the constellation is of any use - that is, if the EU don't scrap it and leave it up there as Space junk. :p
Sorry - a bit off topic. :(
rtk350
