There may be a relatively simple DIY fix to the rear compass noise issue. I have not attempted it yet. However I have discussed the idea with knowledgeable people around here and it does seem that it might work. So let's discuss the idea....
^^^^^ So here is an early build mavic.
^^^^^ and here one that I suspect was manufactured after DJI became aware of the compass EMI issue. Image courtesy of @Thunder-drones who posted this around Christmas time.
It can be seen in the second image how the rear power cabling has been twisted, presumably to reduce EMI/RFI. It has also been re-routed slightly, omitting passage through the two grey retaining lugs at the inside of each yellow circle.
I am quite interested in modifying mine to twist the rear motor power cables in the belief will reduce the rear compass interference.
I see two way to twist the cabling.
a) un solder the rear motor power wires, twist the cable and re solder.
b) Remove rear Arms while keeping cabling attached and rotate them to twist cable then re attach
Option b being less problematic as it does not requiring soldering the motor power wires.
So I have several questions:
1)Has anyone actually removed a rear arm? @Thunder-drones maybe? How difficult is it? Do you think doing so would facilitate the means to twist the power cabling to the main board.
2) Does anyone know precisely where the rear compass is? I have included the image below to show the front compass module and integrated lead.
3) Are their other shielding methodologies that might be easier to achieve DIY?
4) Has anyone who has encountered compass redundancy warnings popped the top on their Mavic. If so would be very interested to see if you have the twist? ie does this fix actually appear to work.
There is no need to point the Warranty implications of doing this. Conversely, sending a Mavic in to DJI opens the possibility of receiving an exchange/refurb unit back which may or may not be desirable.
So I am interested to discuss this idea and here and am seeking suggestions and input...
Front compass highlighted. Note untwisted rear power leads all the way to middle of aircraft.
