DJI GO and Litchi offload from iPad -- very annoying
cinclodes
Alexandria, Virginia
I posted this on the PhantomPilots forum, but I thought it might be appropriate here as well. I have occasionally had an annoying problem and finally realized what was going on and how to avoid it. The iPad has a "feature" in which apps that aren't used for a while will automatically offload. More than once, I have been out in the field ready to make a flight and then suddenly realized that DJI GO and Litchi had been offloaded. Actually, I didn't realize what was going on, but the iPad tried to download the apps, which is hard to do in a remote area with no wifi. In one case, I was able to download the apps by using my phone as as wifi hotspot. I finally found that you can change a setting to prevent unused apps from offloading. I was surprised that nothing turned up at this site with a search on this problem. It seems like it's the type of problem that others would have experienced.
Reactions: RodPad
By offload I assume you mean uninstall?
Seems rather radical in that case, I'm on Android & there unused apps gets it's permissions (like access to sound, position & such) revoked & the app goes into deep sleep (will not be communicating at all regarding updates & will not send notifications while not open in the foreground) , but they can still be started & used.
I have several apps on my iPad that I haven't used for several years, they are still there. What you are saying seems really weird.
Reactions: RodPad
What you are describing is the IOS "Offload Unused Apps" option. If you go to Settings -> General -> iPad/iPhone Storage, you will see this option:
This setting is off by default. You must have enabled it at one point. I do not use this option because I am not low on storage and I don't want any of my apps offloaded. Yours is another example of why I would not choose to use it.
I never enabled this setting. I have an older iPad. Perhaps it was the default on older versions, which have less storage space.
Reactions: RodPad
Well,
This is all true..
The other day my iPhone wouldn't let me take some videos, I found the screen stated unload older apps for space, you can restore from the cloud.
OK, that worked.
Went to use one of those apps, of coarse I knew would need the internet..
Well, I also needed my user, pass, etc. :rolleyes:
Additional
I had a iPhone 4
You use iTunes make a full backup, then do a factory reset, restore iPhone from iTunes.
The backup needs to have a secure password?
Very TEDIOUS
But, it did work!!
To me, its like cleaning up the registry?
I'm using a 12 mini.
I been thinking about trying it again.
Anybody got any other thoughts, let me know.
Rod ..
sofiaschneider
