FAA Got Slapped Down - Cannot Regulate Model Aircraft
Colorado CJ
I knew this would happen, the FAA was expressly forbidden to regulate anything to do with model aircraft in the FAA Modernization and Reform act of 2012, section 336 specifically.
Section 336
IN GENERAL.—Notwithstanding any other provision of law relating to the incorporation of unmanned aircraft systems into Federal Aviation Administration plans and policies, including this subtitle, the Administrator of the Federal Aviation Administration may not promulgate any rule or regulation regarding a model aircraft, or an aircraft being developed as a model aircraft[.]”
Federal Appeals Court Voids FAA Registration Rule For Model Aircraft
Reactions: Kestrel
Wow, so I guess this means no more registrations.I'm ok with this, the likelihood of them actually recovering a registration from a drone that hit an aircraft would be next to none in my opinion anyway.
And the 400 foot rule is now gone and all other rules or recommendations. That being said, its still a good idea to follow them or at-least use common sense.
Not sure the 400 feet and other rules apply to this case as they can regulate airspace, They just can not make up rules as to a person registering a drone.
That said a law passed in Government could implement that into law.
That said a law passed in Goverment could implement that into law.
i
They can't regulate model aircraft which means they can't make rules to what model aircraft can and cant do.
"But the U.S. Court of Appeals for the D.C. Circuit ruled Friday that federal law prohibits the FAA from issuing any rules covering “model aircraft.”"
Appeals court strikes down FAA drone registration rule
According to the forbes article, the government is unlikely to appeal.
They can regulate the airspace that model aircraft fly in, they can not regulate the AC itself, They can regulate where it is flown.
That's not what the link I posted said, if they can't make any rules regulating the model aircraft then they can't tell that person flying the model aircraft that it can't fly 400 feet above or below or anything like that because its a model aircraft.
Reactions: DoubleDrive
"The statute defines model aircraft as an unmanned aircraft that is capable of sustained flight in the atmosphere, flown within visual line of sight and flown for hobby or recreational purposes."
A model aircraft is flown within line of sight , that still screws most of you ,lol
Reactions: moonshine and AyeYo
Ease up a bit.
As an example, the FAA can't regulate registration requirements from other countries, but they sure as heck can regulate their airspace, and who gets in it.
This is a developing issue, but be assured that drone operators are not going have carte blanche in the US airspace system.
They can tell you what your flight height is because they control the airspace you fly IN.
Are you saying that they cant tell you that you are not allowed to fly in restricted areas just because you have a model aircraft?
Does that mean as a hobbyist that you can ignore all no fly zones?
I don't think so.
If YOUR AC is in their airspace they can tell you how high you fly.
Reactions: Jaysjob
Section 336 specifically address the only regulations on UAVs. You say that they can regulate airspace. How does one regulate "airspace" and not what's in it? Think about that. You can't regulate "airspace".... it's space. you can _only_ regulate something that happens in that airspace... which brings us right back to regulations on UAVs.
Reactions: Forrest
I don't think so.
I'm pretty sure things are going back to pre 2015 days.. No one argued about where people could fly then. All these rules and regulation stuff came up when they made us register the model aircraft.
I agreed things are a bit harsh but we do get a lot of (leeway when flying even now in a lot of countries). and i am really not arguing for the fun off it, I just really would not want to be the one testing that in court.
I take the point also that airspace is space. But that space is still regulated and has rules and when it comes to controlled airspace I personally do not think this judgement changes that.
Reactions: HarryMerkin
I think that what the FAA said before this court case happened should still be viewed as common sense, Don't fly stupidly close to airports, stuff like that. Now more than ever people need to use common sense. But i'm pretty sure that you won't get a fine if you fly above 400 feet and certainly not out of line of sight.
Section 336
You need to quote the rest of Section 336 before people celebrate that they're free to do whatever they want.
Reactions: Gary cato
Liger210
