I've been busy buying, selling and repairing Mavics, in addition to working my other full time job, but in my spare time I have been doing some testing and trying to prove fact vs fiction. My last test determined that the mechanics of the Mavic are capable of flying full throttle in sport mode for an entire flight on an 88° day with no overheating issues, and now I have done some more testing.
I was always under the (mis)understanding that flying or running the Mavic with the gimbal protective bubble (not the gimbal clamp) on for any extended length of time will cause the internal temperature of the Mavic to rise. I also thought that leaving the protective bubble on will cause undue stress on the cooling fan and it's ability to provide air circulation with the gimbal cover on. I proved myself wrong today.
Using an anemometer, I clocked the fans output on the bottom of the Mavic at 77mph right under the sonar sensor. There is an outlet there where hot air is dispelled. There are 2 ports at the aft end of the Mavic that I thought were air outlets, but they are not outlets.
I turned on the Mavic with the bubble off, and clocked fan output at the bottom outlet at 77mph. I clocked the rear ducts and received no inflow or outflow at all. The internal board temperature of the Mavic after 10 minutes was 98°. The bottom cooling fins were at 110°.
I then started the Mavic with the bubble on. After 10 minutes on the desk, the internal board temps were at 98° and the output at the bottom outlet was identical to what it had been with the bubble on, 77mph, and the cooling fins were also the same temp as with the bubble off. Again, I found no in or outflow from the 2 aft ports.
My last test was folding up the Mavics 4 arms and doing an inflow/outflow test in folded position. This test led me to the same conclusion as the 2 previous tests. With the Mavic sitting folded on a table and power on for 10 minutes, the cooling fan with or without the gimbal cover was able to expel air at 77mph and not increase the internal components temperature at all. The Mavic does not sit flat on a level surface when folded, it is raised by the 4 folded arms almost an inch above the level surface. That was enough to let air get out of the bottom outlet.
In summary, flying with the bubble on will not increase the internal temperature of your Mavic or make the fan work harder. It might distort your images, but wont have an adverse reaction to your mechanics.
In addition, updating firmware with Mavic sitting on a flat table, arms folded, and bubble on will not raise the internal component temperatures, nor will it impede airflow or place undue stress on your cooling fan. I take off the bubble anyway, but that's just me.
