[["2019-04-26 13:14:39","","Satellite Positioning Off. Fly with caution"]],[["2019-04-26 13:14:40","","Max Altitude Approached. Wait for the GPS satellite signal recovery before ascend."],["2019-04-26 13:14:45","","Weak GPS signal. Positional accuracy may be compromised. Please fly with caution."],["2019-04-26 13:14:45","","Max Altitude Approached. Wait for the GPS satellite signal recovery before ascend."]],[["2019-04-26 13:14:53","","Home Point Recorded. RTH Altitude: 30m."]],[["2019-04-26 13:15:12","","Strong Interference to Aircraft. Signal interruption may be more likely. Fly with caution."],["2019-04-26 13:15:18","","Motor Obstructed"]],[["2019-04-26 13:15:43","","Strong Interference to Aircraft. Signal interruption may be more likely. Fly with caution."]],[["2019-04-26 13:16:02","","IMU altitude error. Please check that the IMU is mounted properly."],["2019-04-26 13:16:02","","IMU altitude error. Please check that the IMU is mounted properly."],["2019-04-26 13:16:03","","IMU altitude error. Please check that the IMU is mounted properly."],["2019-04-26 13:16:03","","IMU altitude error. Please check that the IMU is mounted properly."],["2019-04-26 13:16:04","","IMU altitude error. Please check that the IMU is mounted properly."],["2019-04-26 13:16:04","","IMU altitude error. Please check that the IMU is mounted properly."],["2019-04-26 13:16:05","","IMU altitude error. Please check that the IMU is mounted properly."],["2019-04-26 13:16:06","","IMU altitude error. Please check that the IMU is mounted properly."],["2019-04-26 13:16:06","","IMU altitude error. Please check that the IMU is mounted properly."],["2019-04-26 13:16:06","","IMU altitude error. Please check that the IMU is mounted properly."],["2019-04-26 13:16:08","","IMU altitude error. Please check that the IMU is mounted properly."],["2019-04-26 13:16:09","","IMU altitude error. Please check that the IMU is mounted properly."],["2019-04-26 13:16:10","","IMU altitude error. Please check that the IMU is mounted properly."],["2019-04-26 13:16:10","","IMU altitude error. Please check that the IMU is mounted properly."]]
Is this my fault? Would this be covered under travel insurance or warranty? I also have the video with error messages when is was about to crash.
