Mavic Pro Running Hot? Here's Why
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Found this today.
Basically. Do not fly it with the globe on!
Found this today.
That's not a good test. He should have had it cool down between tests to the same ambient temps.
Or did the globe first and off second.
I don't think he realizes the done has a big vent cut into it either. The fan has plenty of power to pull air through it!
He did.
Listen at 04:51.
MK
Yeah I heard that... however you can tell the sun and the environment he didn't let it cool all the way to the same temp.
He let it cool down a little.
This guy is an engineer, not a scientist. A scientist would have conducted two tests, in controlled environments and would have never used a IR Temp gun to take accurate measurements. He would have also been very specific about the tested areas.
Noticed how he moved the gun around until he gets a higher temp? That's not scientific.
@DroneValley where you at brother?
the-drew
