New pilot reporting in !
Kenogui
Montreal, CA
Site
www.youtube.com
Hi there !
I've just joined the forum, and been using (and enjoying !) a Mini 3 Pro since last summer. My first drone ever.
Coming from photography world, I've been completely seduced by the drone hobby to learn video editing.
And... since I had the money recently, I've jumped the fence and bought a Mavic 3 Pro ! ;)
I will share with you my videos / YT channel in the dedicated channel, glad to join the team ! Thumbswayup
Welcome to the forum! :)
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro and Mvic 3 Pro, including the User Manuals.
After you read the Manual,s read tehm again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Fly On and Fly Safe…
Hi there !
Welcome from the Midlands of England. I think your mini 3 pro won't disappoint. I have a similar history (still photography) and the camera has genuinely amazed me for it's size.
Welcome to the forum from the beautiful woods of Maine!
Reactions: MA2 317
Wow, what an introduction to this forum !
Thanks a lot, everyone, for your warm welcoming, wasn't expecting that much ! 🥰
Reactions: MA2 317
Agreed, its camera is incredible for such a small size. I've already produced a dozen of "serious" footage (intending to do something "clean", in terms of footage quality), and I'm continuing to be amazed by its capacities !
Oh wow, what an extensive advice list ! Thanks ! 🙏
I've already passed several certifications and exams in order to be on track, right off the bat.
In Canada, I have the basic operation exam.
In Europe (I'm French, and go there regularly...) , I have my advanced exam (for my Mavic 3 Pro, mostly, since it's >900gr, I need a A2 open certificate)
And in USA, I have my TRUST + foreign drone notification to FAA.
I think I'm pretty much covered on that front, I'm just hesitating to pass my advanced operations in Canada, in order to fly closer to people and under controlled airspace if required. But since I'm using my drones for recreational purpose, I'm strongly hesitating to add the burden of this exam, because it is quite "intense", in Canada. Even some commercial (manned aircraft) pilots struggle to get it easily...
the-drew
