Strong Interference Signal
EM1205
Hi. May I ask if most probably there's a strong interference signal inside the house. I also read here that calibration shouldn't be done indoor. I tried 2 times already turning on the mavic just to start the propeller but wasn't abke to do this because of the interference. The status of the compass seems normal but the problem is the interference. Is wifi or stone surface affecting this process? Thanks in advance.
Sent from my SM-G935F using MavicPilots mobile app
I get that sometimes when I power up my Mavic to test things inside my house. That message should not appear when you're outside away from all magnetic metal objects.
Reactions: EM1205
dvkhamtruocsinh
