400 Feet - Limitations
jonwyatt
Hey everyone,
In the next couple weeks I will be performing my first commercial operations with my Mavic. I got my Part 107 earlier this month, and I'm excited for the possibilities. However, I am planning on flying over a building that is 200 feet tall. Per the Part 107 rules, I can fly to the height above the building and then 400 feet above that above the building, resulting in a max height of 600 feet. The building is not in class B, C, D, or E airspace, so I will not have issues with that. My problem is that I'll be taking off from the ground, and the DJI Go app limits height to 400 feet. Is there a way to bypass this? I apologize if this question has already been asked.
Thanks in advance!
The limit on the app is 500 metres (~1640 feet) so should be ok. If for some reason there is a height limit problem, the other thing you could do (if you can arrange it with the building folk) is take off from the roof and lower the drone carefully to a negative altitude relative to take off altitude, close to the ground, and then start the official part of your flight.
deepdark
