Air 2 - Small Improvements in Design : Noted !
Phantomrain.org
Approved Vendor
Its seems that DJI recognized some of the Problems with the Mavic Pro and the Mavic 2 and made some subtle improvements on the Battery .
The first improvement seems to be on the battery with the metal Clip , very interesting as this could help with batteries popping out while flying.
The Second possible improvement we see is on the Power Button, as the Power Button on the other Mavic proved to subject to Moisture causing the battery to be compromised this could be a little better in keeping the moisture out.
We also noticed a nicer design on the Props , not as prone to obstructions as some of the other mavics.
The sensors seem to be a little more Protected or recessed which could help with reflections while flying over water flying and into the sun.
These our all subtle improvements over the past Mavics and geared up with the AIR 2 Wet Suits will really make a big Difference in the Extreme Weather Conditions.
Phantomrain.org
email us : [email protected] to be on the List
Gear to fly your Mavics in the RAIN
Coal
Phantomrain.org
Coal
The wet suits allow you to fly in rain/snow? Does it protect the motors too?
These our the same Aluminum Brush less Motors used on both the Phantom and Mavics designed to Negotiate water and used in some Submersibles.
You can check out how the Motors do in the rain ,here is an example of both the Phantom and the Mavic 2 flying with the Wet Suits .
So flying in the rain and snow have never been an issue as we have hundreds of documented flights on the website.
deepdark
