Best cell type for 2s2p configuration
Aurinko
Finland
Is there a better choice for cells than VTC6 in 2s2p?
Looking at the battery test graphs, it looks like the set minimum voltage limit plays a big part in selecting the cell with the highest capacity since high discharge cells don't have much capacity under 3,2V... but what if you set the minimum voltage to 2,8V? Shouldn't the high capacity cells come ahead then? 2s2p VTC6 is only around 2x2900mAh...
edit: took the 10A discharge curve, since it should be quite comparable to the original 20A cell (2s1p) discharge, with 2x10A discharge.
Reactions: pescobar61
Michael Greece
