That's pretty extreme. If you set it to 2.5V, it will undoubtedly crash before then, as even 3.0V drops precipitously fast, and continuing flight will usually destroy the battery, even if you manage to grab it out of the air before the battery can no longer sustain flight.I think I should open a small adjustment in Dji Assistant on the computer, reduce the "landing" voltage from 3.0v to 2.5v.
No, this won't happen. I've done a few flights with these settings when I was flying 10km.That's pretty extreme. If you set it to 2.5V, it will undoubtedly crash before then, as even 3.0V drops precipitously fast, and continuing flight will usually destroy the battery, even if you manage to grab it out of the air before the battery can no longer sustain flight.
My experience is based upon the 4S batteries from the P4P, the Mavic 2, and Mavic 3. The 3S battery from the Air 2 may be more tolerant, especially when the cells remain well balanced and close in voltage. Any large variance in a single cell is problematic when you take them down that low. Don’t ever try flying on partially auto-discharged batteries. That's the kiss of death.No, this won't happen. I've done a few flights with these settings when I was flying 10km.
My opinion is that it didn't make much of a difference. But it didn't spoil it either.
The battery controller has not locked up. I flew on this battery for a long time that year.
At that time, I was interested in making a distance record. It's okay to risk one battery. I gained experience, began to understand where my limit is. The cost of the battery is a small price to pay for experience.That's the kiss of death.
Technically, risking a battery and the drone, as when the battery fails, the drone drops like a stone!At that time, I was interested in making a distance record. It's okay to risk one battery. I gained experience, began to understand where my limit is. The cost of the battery is a small price to pay for experience.
Contrary to my expectations, the battery has not deteriorated. In the winter I changed it to 4S for Mavic Air.
So what speed did you select?In the case of the Mavic Air, no voltage was output. In Go4, this could be done on the Mavic Pro and others.
About the speed. I did a lot of experimenting with choosing the optimal (!) speed. Through the program, Assistant 2 reduced the speed in Sport mode.
That's 30mph. Now I understand why you selected Sport Mode, as I had forgotten that the max Normal speed is only 24 mph on the Mavic Air. On all other DJI drones, the optimal speed for long distance was the maximum Normal or P mode speed, which was right at 31 mph, yet Normal speed was limited to only 24 mph on the Mavic Air. I suspect the optimal long distance speed on the Mavic Air is therefore closer to 24 mph than 30 mph. However, only testing can confirm this hypothesis.In calm weather 48 km/h
Any theory must be proved by practice. I flew 10 km and came back. Other users can prove their theoretical calculations in real flightsI suspect the optimal long distance speed on the Mavic Air is therefore closer to 24 mph than 30 mph. However, only testing can confirm this hypothesis.
Indeed. However, there is a reason DJI lowered the Air 2 P/Normal speed max to 24mph. I'm just suggesting that you could have gone farther at 24mph than at 30mph, assuming transmission range was not an issue. 10km for an Air 2 is good, but had you not been flying at an inefficient 30mph (for the Air 2), you likely wouldn’t have needed to take the battery to well below 0% to accomplish it. Why did you choose 30mph? Had you first tried 24mph, and were not satisfied with the results?Any theory must be proved by practice. I flew 10 km and came back. Other users can prove their theoretical calculations in real flights
So, from your recorded data, what was the difference in total distance distance when flown at 24mph vs 30mph, all else being equal?I made about 50 test flights. Testing speed, height, climb rate, smoothness of ascent, signal quality. Recorded data, analyzed battery consumption with a wattmeter.
1-1,5 km over a total distance of 20 kmSo, from your recorded data, what was the difference in total distance distance when flown at 24mph vs 30mph, all else being equal?
That's a relatively small difference that could easily be attributed to other factors like differences in wind, temperature, and variances among different batteries (# of flights, degree of prior battery "abuse", percentage of useful life remaining), and differences in battery starting voltage and ending voltage.1-1,5 km over a total distance of 20 km
Asking for details in how you conducted your 50 test flights isn't arguing. I am not disputing your flight in any way. I am only questioning your separate conclusion that 30mph results in a longer flight distance than 24mph, when all other variables are properly controlled for. When conducting a scientific test, one needs to control for all other variables, other than the one to be tested, which in this case is total distance. The confidence level in the results completely depends upon the margin of error in the control of each of those different variables. Otherwise, you have a mere corellation instead of a causation. Just because A follows B doesn't mean that A caused B.I will not argue. But my Air flew these 10 km, taking into account all factors. And your?
