Mavic Mini FCC Version Hack for Full Power in EU
Seems like quite a lot of faff when you can get a CE version in the EU and have control at over 2000m and still have an easy path for warranty issues.
For someone like me, it matters. I live in India, bought it in the US, but will use it in EU also.
Our Italian Friends are on it. They made this video for the FCC Version of the Mavic Mini. It's about unlocking Full FCC Version Power when flying in Europe
Two questions Which Fake GPS app for android? And, will this affect the return to home?
I presume RTH will be locked to the GPS recorded on the AC, so shpuld still work?
Dont affect. when you put the mini on air without gps, assumed that you are inside. After 20 -30 seconds stationary, gps is working correctly and automatic set home "REAL" after that you can fly away the mini. RTH worked fine.
The flight log. In second 30 automatically set home
TimeFlight ModeGPSAltitudeSpeedHome
Distance
BatteryBattery
Voltage
Cell 1Cell 2Cell
Deviation
Message
0m 0.4sStarting Motors0satellites0ft0mph0ft0%8.202V4.102V4.1V0.002V
0m 1.1sManual Takeoff0satellites0ft0mph0ft97%8.202V4.102V4.1V0.002V
0m 1.9sP-GPS0satellites0ft0mph0ft97%8.202V4.102V4.1V0.002V
0m 2.6sP-GPS0satellites2.0ft0mph0ft97%8.166V4.085V4.081V0.004V
0m 2.9sP-GPS0satellites3.6ft0mph0ft97%8.166V4.085V4.081V0.004V
0m 5sP-GPS0satellites4.9ft0mph0ft97%7.997V4V3.997V0.003V
0m 10sP-GPS0satellites4.6ft0mph0ft97%7.964V3.983V3.981V0.002V
0m 14.2sSport0satellites4.6ft0mph0ft96%7.942V3.972V3.97V0.002V
0m 15sSport0satellites4.6ft0mph0ft96%7.931V3.967V3.964V0.003V
0m 20sSport0satellites6.2ft0mph0ft96%7.92V3.961V3.959V0.002V
0m 25sSport0satellites7.2ft2.1mph0ft96%7.801V3.948V3.853V0.095V
0m 28sSport0satellites9.5ft0mph0ft95%7.914V3.943V3.971V0.028V
0m 28.4sSport0satellites11.5ft0mph0ft95%7.914V3.943V3.971V0.028V
0m 28.9sSport0satellites13.5ft0mph0ft95%7.808V3.905V3.903V0.002V
0m 29.8sSport4satellites15.1ft0mph0ft95%7.889V3.946V3.943V0.003V
0m 30sSport4satellites15.4ft0mph0ft95%7.889V3.946V3.943V0.003V
0m 31sSport7satellites16.1ft0mph0ft95%7.89V3.945V3.945V0V
0m 35sSport7satellites16.4ft0mph0ft95%7.866V3.937V3.929V0.008V
0m 37sSport9satellites16.4ft7.0mph0ft95%7.872V3.938V3.934V0.004V
0m 39sSport10satellites16.7ft0.3mph0ft95%7.828V3.917V3.911V0.006V
0m 39.3sSport10satellites17.1ft0mph0ft95%7.828V3.917V3.911V0.006V
0m 39.4sSport10satellites17.1ft0mph0ft95%7.828V3.917V3.911V0.006V
0m 39.5sSport10satellites17.1ft0mph0ft95%7.828V3.917V3.911V0.006V
0m 39.7sSport10satellites17.1ft0.2mph0ft95%7.867V3.935V3.932V0.003V
0m 40sSport10satellites17.1ft0mph0ft95%7.867V3.935V3.932V0.003V
0m 41.4sSport9satellites17.1ft0.2mph0ft95%7.869V3.936V3.933V0.003V
0m 42.4sSport10satellites17.1ft0mph0ft95%7.867V3.934V3.933V0.001V
0m 45sSport10satellites16.7ft0mph1.1ft94%7.859V3.931V3.928V0.003V
0m 50sSport10satellites16.7ft2.7mph3.0ft94%7.845V3.924V3.921V0.003V
0m 50.1sSport10satellites16.7ft2.9mph3.1ft94%7.845V3.924V3.921V0.003V
0m 50.2sSport10satellites16.7ft2.7mph3.3ft94%7.845V3.924V3.921V0.003V
Reactions: deepakvrao
Fcc hack works also with CE version. On 5.8 ghz band it boost some decibels just enough for double range. On 2.4 ghz there is no change in power (based on videos on this youtube channel).
hi, where did you read this in yt? never heard about this...
Dirkstruan
here is youtube channel with a mavic mini testings. They have CE and FCC version and they tested all variants with and without FCC hack with RF meter and then distance tests with all variants.
I tried 1 time in city.
without hack --> 400m far and 150m high
with italian hack --> 1.100m far and 500m high
Sorry for the probably dumb question, but which hack exactly are you talking about and could you provide instructions or a link so I can unlock my own MM?
The hack was done by using an app called fake gps. Check out the youtube video in the first post.
Reactions: dawaske
I saw the mm teardown which showed a different 5gz transmitter for the FCC version which has an amp. How would the hack help if an actual hardware is the difference between the ce and FCC version?
Reactions: Ping^Spike
With fcc hack you don't get full fcc power with CE version, it just adds some decibels power gain on 5.8 ghz with CE hardware and this is just enough for double CE range. However this power gain is still small amount compared to FCC power level.
But don't know how it is now with latest firmware if fcc hack still works or not anymore. One with RF meter could try this :)
Reactions: atsphenomenon
At this time, Italians shown measurements on remote controller only.
Noone knows if the drone boosts his power too.
So, we can expect with FakeGPS, the drone keep his 25mw cause drived by his own GPS module, and fooled RC has 1000mw (?)
Living in Europa, I'm waiting for a new FCC model and l'll do measurements, if someone can't do it before.
Also has any body used it regularly and can recommend it
I can confirm FCC works great here, at Spain (europe), flying 1.0.3 firmware and 1.0.6 DJI Fly app version. For me, FCC hack doubles my range from 500 to 1000 meters at urban environment.
I followed all the detailed steps as read into this thread, but faced a problem when exit DJI Fly before landing in order to preserve hack. I realized that forced exit from app causes flight log corruption. Flight path ends abruptly in mid-flight, end half of flight path is missing. Looking for alternatives I succeed landing drone in a normal way (using DJI Fly app) but turnin off Mavic Mini as soon as it touches down, before it can process the changing WIFI region command from controller.
Best regards.
R.
Best regards.
R.
Do you have a CE or FCC version mini?
IOS or android phone ?
Im assuming you are flying in 5.8 GHz ?
deepdark
