No Obstacle Avoidance
Nafasi
Cleveland
My Obstacle avoidance on my Mavic 3 is not working. The avoidance indicator stays red all time and I get no audible warnings at all.
If your in sports mode it turns off OA.
There's also a setting in the menu to turn it off and on.
Check both above to be sure..
I'm sure you meant "Obstacle" avoidance. Therefore I changed the name of the thread and edited your post accordingly. If I'm mistaken, kindly let me know
Also disabled in low light & night
Thank you for your response, I checked it and it wasn't working in any mode. I'm going to recalibrate this morning when I take it out to see what that does.
You are testing while flying also? Cause on the ground OA is off. It turns on once in the air. But again check settings to be sure OA is turned on as well
deepdark
