Pairing problem Mavic 3 Pro
You don't connect to the Mavic 3 with Bluetooth ... Your frustration will quickly fade away if you read through the user manual, the linking process is well described there.
User Manual --> https://dl.djicdn.com/downloads/DJI_Mavic_3/DJI_Mavic_3_User_Manual_v2.0_en.pdf
Below is from page 58 where the linking procedure is described...
You also need to manually download & sideload the DJI Fly app to your phone, DJI doesn't publish it on Google Play anymore ... if you find it there it's outdated.
Here you download the DJI Fly app --> Mavic 3 - Downloads - DJI
Hello from the Crossroads of America MadeSlowly
Nice to meet you Sally. 🤝
Hopefully you'll get your problem resolved soon.
Welcome to the Forum. :cool:
Thank you for advice. Will read tomorrow. Have downloaded manual too. Have djifly from the dji website already. 🤞
Read the info slup wrote in post #4
Since you live in Australia, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mavic 3 and Mavic 3 Enterprise, including the User Manuals.
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Happy Droning…
Welcome to the forum. We look forward to your participation and your view of the world.
Sally: Welcome to the forum from Chicago the Windy City.
FLY SAFE & FLY SMART
Reactions: LoudThunder
pilot74sparki
