- Joined
- Oct 12, 2016
- Messages
- 28,463
- Reactions
- 31,382
- Location
- Harrisburg, PA (US)
- Site
- mavichelp.com
Yes, that memory card will work.Is this one of those fast/on the list cards?
The memory card you linked above is advertised as having a 100 MB/s read speed. The write speed is more important since the Mavic Air is writing data to the memory card. I did not see the write speed documented anywhere. In one of the Amazon comments, someone said it was able to write data at 28 MB/s. On another webpage, the write speed was listed as 10 MB/s.
The Mavic Air is able to write data to the memory card at a max speed of 1000 Mbps (or 12.5 MB/s). That means you'll want to choose a memory card that is able to consistently write data at more than 12.5 MB/s. The write speed can fluctuate, so you don't necessarily want to choose a memory card that is able to write at a speed that's just a bit faster than 12.5 MB/s.
I had a slow class 4 sd card to start out with. Says slow card. I get this new card, and still same....slow card warning. Formatted it, restarted all, drone, controller and app. Any ideas? This card is rated write speeds up to 90 .
I had the same issue. Thought it was my card so I bought another. Same same. I was formatting the cards using the drone. Did some reading and found that this place (see link below) comes highly recommended for formatting sd cards - especially the fast ones. So I formatted both cards using their system, put each one back in the drone and all was good. Give this a try.
SD Memory Card Formatter 5.0 for SD/SDHC/SDXC
It came in this package
Ok. Might just be the photo but it looks dodgy to me.
I use these also and they work great!I actually changed my.order to this...
Card with Adapter (MB-ME128GA/AM)
Amazon's Choicefor "128gb micro sd card"
Size:
128 GB
Style:
Card and Adapter Only
$ 44 99
It's the higher bitrate which needs the absolute fastest card, Hero4 bitrate at 4K is similar to Mavic Pro, about 60 compared to Air at 100.
I've seen the same with my Sony RX100 using the highest 100mb setting.
Formatting did not help. Slow card is slow. Just to confirm, Samsung Evo Select (green colored) worked in MA. No warnings. That card right now is on sale and the cheapest 64gb that's confirmed working for MA. $20 for 64gb.Samsung pro card (white/silver) that worked great in my GoPro Hero 4 Black, gave warning in my MA as too slow. Guess I will give formatting a try and see what happens. That card is pretty fast or so I thought. Bummed. Anyway, I ordered a 64GB Samsung Select just in case.
Yup, confirmed working at 4k of Mavic Air. Great price too.
