Code
Jiker69
APGS Signal Weak. Hovering unstable. Fly with caution (Code 30002)
Is anyone familiar with this? Thank You
Also, I know there is a program that will show the movement of the sticks. I used it once and now I forget what it was. Don't remember if I loaded the KML file or what.
GPS signal weak - your drone has probably lost GPS.
Post your flight data for assistance.
What you were looking for to show joystick movements is also the way to post your data.
There are a couple of options ...
1. Go to DJI Flight Log Viewer | Phantom Help
Follow the instructions there to upload your flight record from your phone or tablet.
That will give you a detailed report on the flight data.
Come back and post a link to the report it provides and someone might be able to analyse it and give you an understanding of the cause of the incident.
or
2. Just post the .txt file here
or
3. If you use Airdata, you can view the flight data on Airdata and post a link for the Airdata report
Reactions: RodPad
Good morning Jiker69 the code along with the warning you received usually indicate that your Wi-Fi board needs to be replaced. You should try and go thru the entire recalibrations for the drone.
You can also try and reinstall the software and see if this clears up the problem.
???? That just doesn't add up.
What does a wifi board have to do with unstable hovering?
If the wifi board is the problem, what would recalibrating do?
What do you suggest should be recalibrated?
Why suggest reloading software?
Reactions: RodPad
It means that your drone hasn't got good GPS reception.
It might be because you in an area where GPS signals are blocked by obstacles, or indoors etc.
If you are out in the open where the drone has a good skyview, it could be that the drone's GPS receiver is broken or not connected.
Reactions: RodPad
LOL MAN SORRY yes it is a GPS error not a wi-fi SORRY my first cup of coffee! PLEASE ignore my advice above and thanks for the correction.
Reactions: RodPad
joel_du05
