- Joined
- Jan 7, 2017
- Messages
- 70
- Reactions
- 66
- Age
- 44
Reasonable question- all he is asking is if the BT-300’s might be upgraded to android 6.??? Support for accessories that cost twice as the drone. You are a funny guy! The drone is a new beginner drone.
And how might you propose Epson could enable the app to run on Android 5? The Fly App requires Android 6 as a minimum.I believe they will not upgrade the Unit, but they certainly can enable the app to run with the BT-300 as it is.
Well, they can compile the app to work on any android version they consider or want. DJI and Epson have collaborated in the past to make DJI GO and Soar work in the units. I don’t see why not this time. If we could only hope or wish for the best instead of assuming the worst. They can do it and I believe they are listening to their customers.And how might you propose Epson could enable the app to run on Android 5? The Fly App requires Android 6 as a minimum.
Im not sure what collaboration was required for GO or soar. It is easy enough to side load apps (the epson store availability isn't important).Well, they can compile the app to work on any android version they consider or want. DJI and Epson have collaborated in the past to make DJI GO and Soar work in the units. I don’t see why not this time. If we could only hope or wish for the best instead of assuming the worst. They can do it and I believe they are listening to their customers.
